Shimadzu BL 2200 H
30/3/2007 07:49PM
Buenas tardes, tengo un inconveniente con balanza Shimadzu Modelo BL 2200 H la cual marca "oL". Según el manual seria celda de carga con sobrepeso pero se realizó todo lo conocido por eliminar el sobrepeso como en otras balanzas pero no resulto. Si alguien tiene conocimiento le agradeceré me envie algun dato mas.
01/4/2007 11:05AM
BL Calibration – Shimadzu
This instrument uses a menu structure to set internal configuration parameters. That menu is accessed using the TARE key to go to a lower menu level, or the POWRE/BRK key to rise in the menu structure. The highest level in the menu structure is standard weighing mode. Continuously pressing POWER/BRK causes the instrument to return to standard weighing. In the following example of Shimadzu BL-2200 calibration, a 2000 gram weight is called for. Other models in the BL series will requires different weights.
Action Result
1. warm up 30min, level, tare to zeros
readout shows 0.00
2. Press CAL/MENU
readout shows CAL
3. Press TARE
readout shows required weight , blinking 2000.00
4. wait for stability arrow
 2000.00
5. Place the indicated weight value on the pan
2000.00
6. Wait for stabilization
 2000.00
7. Press TARE
0.00 blinking
8. Wait for stability
 0.00
9. Remove weight from pan 0.00
Wait for stability
Press TARE CAL End or CAL E 4
shows on readout .
10. Instrument returns to weighing mode automatically.
comentario
