[Solucionado] colegas, no puedo calibrar la tscale modelo skw 30
11/1/2017 10:14AM
probe con distntas calibraciones y no he podido
se descalibro al cambiar bateria
Necesito la calibracion o manual de la misma
Soy tecnico
11/1/2017 10:37AM
Try with this one:
-On the main borad put jumper on K3
-Swich scale and push F while scale starting up, PIN is on the display
-Type U, (printer key) and T
-Unload is on the display, push Zero key
-Maximum is on the display, push Zero again
-Load is on the display, put max weight on the pan and push Zero
-PASS is on the display and scale switch to weighing mode.
-If everything ok, turn off scale and take off jumper
