Calibracion de Indicador IND780
10/1/2017 04:45PM
Buenas Tardes Favor tengo una balanza con este indicador q tiene diferencia de peso, favor si me pudieran facilitar el manual de calibracion.
de ante mano les agradesco
Jose Luis
11/1/2017 01:24PM
Hello,
for the installation and internal switches location, you may have a look at the "installation manual"
(http://www.mt.com/id/en/home/library/installation-instructions/industrial-scales/IND780_Install_Manual/_jcr_content/download/file/file.res/64057253_R13_IND780_IM_ML.pdf)
For the calibration, when using analogue load cells, it is under menu "scale". "Capture Zero", "Capture Span" and "Step calibration" might be using with known weights. It seams that you must be logged with an administrator account.
The procedure seams to be quite the same that for IND560 for example. A video can be found at
I do not have done this with a IND780 yet, but you may try if it works.
Hope this can help you,
Regards
